Wyze bulbs and Alexa
Is there a way to have the Alexa app recognize the bulb groups, instead of individual bulbs?
I have 3 groups, with 3 or 4 bulbs in light fixture.
I’d like to be able to say “Alexa dim the LR”
You can’t get them to recognize the WYZE group as far as I know, but you can also set up groups in Alexa and it will recognize those.
Yes Alexa can recognize WYZE bulb groups. Go to Alexa- Devices and scroll down to find the bulb group you setup on WYZE. Click on the group and then find the individual bulbs in that group and check the box corresponding to those bulbs. Save it and you are done.
