How can I change the WiFi network of my Wyze Bulb White’s? The only option I found so far is resetting them, though some people were complaining not to be able to join them again after reset.
You need to do the reset on the bulb and then go through the setup for it. If you don’t delete it from your app and add it back, you should maintain all of your rules associated with them.
I have not had any issues with resetting them to pair with my network. So not sure if the issue you mentioned was an earlier version of the app or firmware.
