Wyze Bulb Color wont factory reset and only lights up red
My wyze bulb color only lights up red. In the app it shows as offline and wouldnt let me connect to it. I tried factory resetting it by flipping the switch on and off 3 times (multiple times) and it still only lights up red. So the factory reset didnt happen. I tried deleting the bulb from the app but its still only illuminates red. Now i cant connect the bulb to the app because it wont go into setup mode because the factory reset sequence apparently fails. I moved the bulb to another socket and it still only lights up red. I left it on for quite a while (illuminated red) hoping that after being on for an extended period would bring it to some stable state but that doesnt seem to work either. Factory resetting is still not working.
I tried searching the forums and online but it seems like no one else has had this issue. I emailed support (Wyze Ticket 1557782) but it seems like my issue is not understood. Its not a connectivity issue, its not a placement issue and its not a configuration issue. The bulb wont factory reset. Its just red.
Anyone else have this problem?
I had that problem with one of my 12 color bulbs. If you can’t get the bulb to initiate the reset, it is most likely considered dead. Your best bet for personal service in this case is to speak to a Wyze employee/representative. Please contact them directly at:
Wyze Customer Support: (206) 339-9646
Available Monday - Friday 4 am - 8 pm PT
Saturday 8 am - 4 pm PT
If you can obtain your Order Number and date, please have it handy before calling.
I know this has happened to me before with a different bulb color, but i cant recall how i was able to reclaim functionality.
I’m having same issue. Were you able to figure out a solution?
@Seapup gave a solution.
I have the exact same problem … Color stuck on red tried all the troubleshooting tried resetting it make sure it’s on 2.4 GHz blah blah blah I thought I wrote your question LOL hopefully somebody can help
I also have this problem with one of the two bulbs I just purchased , One works just fine and the other is red and won’t pair , I did try all the trouble shooting methods to no avail , I will be calling them tomorrow unless someone has any other info that I may have missed .
Same problem here with the first bulb I purchased to see how we liked it. I had such high hopes! :frowning:
I have the same problem with one of 2 color bulbs i purchased recently. I think it was post firmware upgrade is when it happened. I am no unable to factory reset nor connect to the bulb in the application anymore. Frustrating for sure.
yo compre 10 de ellos y hace 3 dias a 3 de esos focos solo estan en rojo ya no funcionaron solo se quedan en rojo no se reician no nada la vdd que molesto y no encuentro por ningun lado ayuda para resolverlo o de plano ya estan muertos
