Re-pair my wyze color bulb
Hello. I initially had my Wyze color bulb. Software updated and now the bulb is stuck on red. Giving a hard time to be reprogrammed. Help me plz.
Moderator Note: Personal information has been manually removed from this post. Such information often gets included inadvertently in an email signature block when replying by email. The forum software attempts to automatically remove email signatures but it is not always successful. When replying to the forum by email, it is best to remove the signature block yourself before sending.
This is a user to user forum, you may want to leave out your contact info.
@sandrenej As @towelkingdom thoughtfully points out, this forum is primarily a user-to-user community and is not monitored by Wyze Support. If you don’t get a helpful solution from a fellow user here, you should contact Customer Support (206) 339-9646 Monday - Friday 5 am - 6 pm PT and Saturday 8 am - 4 pm PT.
Your personal contact info has been removed from your post for your safety.
Welcome to the community @sandrenej
Since it is stuck on Red, I would remove the bulb from your app, do a factory reset and then repair them. Here is how:
However, if you want to try something before you do this:
Option 1
  • Power off the bulb by either unscrewing it or turning power off to it
  • wait for about 1 minute or longer if you can
  • Put the power back to the bulb and wait for about 30 seconds
  • then start the app and see if you can control the bulb.
Option 2
  • Start your app, go to account then App Setting and clear the cache.
  • Shut the app down
  • If you have Android, Long Press the App then select Force Stop, the goto Storage and Cache and Clear the Cache there
  • Restart your Device, go into the app and see if it works.
I had the same thing happen when updating. They are replacing the bulbs after trouble shooting. Must be a thing
