Wyze Bulb Cam & Battery Video Doorbell Firmware Beta Test 1/26/2026
Wyze Bulb Cam:
Version: 21.1.6.1117
What’s new:
  • Fixed a bug that will cause event recording outside detection zone
  • Fixed a bug that will cause the device Wi-Fi setup to fail
  • Image quality improvements
  • Fixed a bug that will cause the device to go offline
Wyze Battery Video Doorbell:
Version: 1.0.0.2083
What’s New:
  • Improved connectivity stability and resolved an issue that could cause cloud video uploads to fail.
  • Updated to the latest camera SDK version to improve the connectivity quality and resolved the issue that app settings could not be saved.
  • Fixed the issue where unexpected battery drain of the SoC could prevent the MCU from reinitializing the SoC, leading to a device hang.
  • Other bug fixes.
Looking forward to this fix. The issue has been driving me crazier than I already am. Applied to one Bulb Cam. No doorbells to test.
@WyzeAndy might this have been what has been happening with Duo as well when hardwired? it loses connectivity.
This firmware seems to have fixed the problem where I could not set it to record 24/7 to the SD card even though it is connected to power. Thank you,
Updated Wyze Bulb Cam. Working smoothly so far will report if any issues are found.
