I am installing four bulbs in one fixture. Three of the bulbs set up just fine. The fourth bulb would not update to the new firmware and just kept flashing. I uninstalled and did a factory reset on the bulb and all it does is flash when I reinstall it and will not update. I’m thinking I got a bad bulb. Because all of the other bulbs work just fine, I’ve even move them around to different sockets and the three installed worked fine but the fourth or not.
Welcome to the forums! Got a few questions for you:. Are you setting one up at a time seperate from the rest? Are you using a fixture with a dimmer? Is mobile data off on your phone while setting up the bulbs?
I don’t know how to turn off mobile data on my moto x4
