I just purchased a Cam v3 and am disappointed that the SD Playback interface from the SD Card does not match the Cam OG interface.
The Cam OG SD Playback interface’s vertical layout and the icons for movement and sound are a great little feature.
The Cam v3 SD Playback interface is horrible with its horizontal scroll you cannot see anything.
Please update the SD playback interface for all camera types to match the new Cam OG layout. The interface should be uniform across all Wyze camera models.
[Mod Edit]:Title, tags and request text modified to enhance search clarity. [Mod Note]:This request is the inverse of the following wishlist topic: Cam v3 Pro - Revert to old V3 Playback UI
There was a consistent UI (except required camera specific additions such as pan controls on pan cameras). Wyze has developed a new UI which essentially is being tested on a couple of camera models and will be migrated to all the cameras once the new UI is finalized (still a few tweeks to it based on user feedback). At least that’s the way I understand it.
The new UI is growing on me. Once you have navigated to the desired date, you can see the old UI by turning your phone/tab to horizontal/landscape orientation.
I would love to see all cams on the same UI, or at the very least have the same feature options available on all cams with the same Settings Menu options and UI when they have those features available. Even the new UI is missing options for some cam versions.
But, as has already been mentioned, totally reprogramming the UI for all the older cams is much like retrofitting all new features on an old car. It just isn’t financially feasible.
Integrate new Cam Pan v3 user interface to other Wyze cam types
The new Cam Pan v3 user interface is great. Makes it much easier to go back and view old recordings from the SD card. Having that interface on the standard Cam v3 (and other cam types) would be great.
[Mod Note]:Your topic and votes were merged to this Wishlist request for better visibility and consistency in grouping similar requests.
