Wyze app not finding headphones
The same turning off my Samsung watch worked for me.
omg, WYZE!
This is NUTS! lol
I already started a support ticket, but since they appear swamped, I came here…read the comments about needing to make sure nothing else is currently ‘connected’ via bluetooth, tried it like that, and it worked just fine. :expressionless:
Thanks again, All. :hugs:
Great tip! I have been trying to pair my headphones for a couple of days. I used another phone and voila!!
Unfortunately, after finding the tip here, and using it to get mine paired via the Wyze App, they ceased to work properly, and started this BEEP that happens every few seconds or so.
Also unfortunately, they appear to be so swamped that I don’t have any idea whether they will ever get back to my support ticket.
Not freaking out. I have other good headphones, and with how small the earholes are on these Wyze ones, I’m only keeping them because I’m an idiot, and already drank the Wyze kool-aid. lol
It worked! Alexa is now fully functional via the double tap process!
I have the exact same problem and have tried everything suggested to fix, yet nothing. I have a Samsung S10+ and am also running the app on it with no problems at all on my other devices (various cameras and the Wyze scale). The headphones actually work very well with the phone (pairs to, play calls and music) just cannot and them to the app hence am unable to get updated firmware, etc.
It was the Samsung watch for me, too. Thanks for that.
Thanks!! i was crazy trying everything and then found your post. Disconnected my smatwatch, try again and it works just perfect… thanks
I do not know if it helps. But I found if you have a smart watch or anything else that is connected for phone calls, that seems to be what prevents the connection. I left my watch attached and just turned off the connection for phone calls and I am able to connect without issue.
Thank you for the tip. Once I disconnected my Samsung watch I was able to add my Wyze headphones to the app. I noticed that anytime the phone is connected I cannot connect the headphones to the Wyze app. Something for the people at Wyze to work on.
THAT DID IT! Thank you for the post. I disconnected my Samsung watch and the headphone connected via the app as it should.
I have the same issue, Alcatel 508R phone (I know cheap). I tried using my Yoga tablet to get it to work in the app but still no luck. When I first tried to upgrade the headphones firmware I left my phone and headphones at home while I ran an errand. When I got home my phone said upgrade failed. They connect via bluetooth but I have no control. I put in a ticket and sent logs from app and headphones. Does anybody know how of if I can force the headphones to a factory default so I can try the upgrade again?
I wanted to add my contribution to save a future person some frustration. I couldn’t add my Wyze Headphones to the app and after trying every tip i could find and combination of power cycles, clearing the bluetooth list, disconnecting from all devices, not turning on until prompted, etc, etc., what worked for me was realizing my headset WAS ALREADY ADDED to my wyze device list.
It would be great for wyze to throw up an error saying “This device is already configured”
