Wyze app 3.7 & Bulb cam Firmware Beta Test 7/31/2025
3.7 Beta:
Versions:
  • Android:3.7.0.b685
  • iOS:3.7.0(5)
What’s new:
  • Passkey login now pops up at launch.
  • Ability to add Wyze Shortcuts directly to Siri. (iOS ONLY)
  • Bug fixes
Wyze Bulb cam:
Version: 21.1.3.0849
What’s new:
  • Optimized color Night Vision effects by reducing smear
  • Optimized 2-way audio performance by reducing wind noise
  • Optimized RAM usage to reduce reboot risk
  • Security Updates
Updated without issue.
Samsung S24 Ultra
Samsung A9+
Interesting update for Cam V3 users. I think they unified the UI design so it is like similar to OG / V3 Pro / V4. The timeline now shows event icons.
It can now split screen when live viewing and scrolling recent events. There’s an option to even filter the events (even in landscape mode).
It’s odd they don’t mention it in the What’s New notes. Kind of dramatic.
Don’t they simply say, “bug fixes”? :rolling_on_the_floor_laughing:
Yah. :grin:
Some people here don’t fancy the UI change, no idea how many, but certainly many people in the v3-only customer base will chafe at a major change, having adapted to the shortcomings of the old UI, now needing to adapt to the new, or roll back the app and hunker down after it auto updates, which is only possible/practical with Android, I think, and is no longer as painless as it used to be even there.
big_gal
To all:
Be careful.
Updated yesterday without issue. All seemed normal until about 7:30 pacific time. Then I noticed that some of the thumbnails on my favorites and events screen were missing. Thought this was odd so I re-cleared the app cache. This did not help.
Logged out of app. On reload I got a blank Google screen. I tried a few more times without success.
I restarted the phone and reran the same steps. It did not clear.
Then went to my tablet but did not logout. Took a screenshot of the missing thumbnails.
I am not sure if this is a beta issue or if Wyze is having cloud issues. I did not notice the issue for almost 24 hrs which makes me lean toward a cloud issue. Waiting for everyone to leave the house. Will restart the network.
I can live with some missing thumbnails but not being able to login is a big deal.
Anyone else noticing this on beta 3.7.0 (b685)?
It was a cloud issue. As of 8:47 pacific time all cleared. I can log in and all thumbnails are back.
It could have been anywhere on the internet but only Wyze knows I’m logging in and what a thumbnail is.
Doesn’t matter. It’s fixed. Was only down for a couple of hours. And if it was Wyze–good job, your backup strategy worked.!
“This message approved by Lauren Sánchez”
:laughing:
The beta app updated fine for me. I have a mix of V3 and older V2 cameras and a Doorbell V1. The UI update for the V3 cameras is very well done. I wish this update would make it to the older devices.
One bug - the video feed for the Doorbell V1 initially loads rotated 90 degrees. Once it establishes the stream the video appears correctly oriented vertically, but the original rotated image persists in the background.
I’m asking out of curiosity, because I don’t have the Video Doorbell (“v1”) and don’t use iOS: Are you seeing this on both platforms? I notice your profile here says that you use “Both iOS & Android”, so noting whether this is a platform-specific bug could be helpful for troubleshooting before this advances to RC or production status.
Thanks for taking the time to share feedback!
The only “Android” that I still use now is an emulator. I can try to reproduce the issue but I don’t know if this would be worth while since it is not an official platform.
I had the same issue on my IOS phone. I did restart phone but not camera and now it seems like image is correct orientation. As to changing home screen option in settings, I actually liked the new format except it doesn’t allow you to toggle live view videos. For that reason, for now, I am back to “Comfortable” versus “Condensed” camera view in “app” tab of “Account” settings…just in case others may not have played with it yet.DJ
Feedback:
In the new camera UI, with the timeline view, it is not clear when there is a large gap in the time, especially when the gap spans over midnight. Large time gaps should provide a visual indicator (perhaps a wider or gradated dividing bar). Additionally, the date or day of the week should be shown when the day changes on the timeline.
Not sure if anyone else has noticed, but the new app 3.7 on iOS it notifies when the cameras are disconnected/powered down.
I see this, too, on Android.
It also notifies you when the cameras come back online.
Good job Wyze! :+1:
:glasses: :window: :eye: :wing:
:point_up: Expand for better context.
