Wyze app 3.4 RC - 3/6/2025
Version:
  • Android: 3.4.0.b635
  • iOS: 3.4.0(5)
What’s new:
  • Fixed a crash issue that occurred when Cam Unlimited Pro users changed the Cloud Storage time without an internet connection (iOS).
  • Resolved an issue where Cam OG took too long to load SD card videos (iOS).
  • Bug fixes. (Android)
@WyzeJasonJ,
Just posted on Play.
Updated without issue. So far so good.
Same for me. Installed and everything is looking good. Will report back if I find something
New to this. This is my first post, so I might need some guidance. Never tried the Cloud Storage Time. My OG is the Telephoto, and SD card videos load quickly, just a second or two. Other than the OGT, I’ve swapped out all my other cams for the V4’s because I use them mainly for NIGHT WILDLIFE. The OGT is used to see if the postman cometh.
Found an issue with Android App RC 3.4.0.b635.
When Viewing events, when you start looking at an Event in Portrait mode and then rotate the phone to the right for Landscape view, the stream starts to look ok and then flips 180 and looks upside down.
Log Submitted: 1797132
Note: Rotating to the Left seems to function ok and no issue is found on iOS.
Unable to view sd card recordings on one of my v2 cameras.
For those users on the 3.4 beta apps, tonight the Emergency Dispatch button, located on the upper right of the monitoring tab, will go live in anticipation of the public release of the app.
This means if this button is pressed it will now contact Noonlight instead of being in a testing sandbox.
Seems intermittent:
