2.46 App iOS Release Candidate #2 & Wyze Battery Cam Pro Firmware Beta Test 10/16/2023
2.46 App iOS Release Candidate #2:
Version: 2.46.0(4)
What’s New:
  • Improved UX when adding cameras to camera groups
  • Bug fixes
Wyze Battery Cam Pro Beta:
Version: 1.3.20.1993
What’s New:
  • Fixed a bug that caused the battery metrics report to turn on the spotlight at midnight when the motion detection zone was turned on
  • Fixed a bug that caused the livestream to disconnect when the microSD card was set to record continuously
  • Fixed that bug that caused the livestream to disconnect after the network was restored when the microSD card was set to record continuously
  • Fixed the bug that caused recording to the microSD card to sometimes not start even when set correctly
Installed and will begin testing
EDIT
@WyzeAndy @WyzeJasonJ
Battery Cam Pro Testing
Log Number: 1205244
App Version: 2.46.0 (b365)
FW Version: 1.3.20.1993
I am testing the BCP Beta FW. One thing I am noticing is with the double tap to zoom. When I double tap, the camera zooms in to the center more or less. However, on the other cameras it will zoom into the area you double tap. I would expect this to function the same as the other cameras. I tested this functionality with the V3, Vepro, and OG all of these will zoom to the location you tapped. the BCP will not.
Battery Cam Pro Testing (x2)
Android App Version: 2.46.0 (b365)
I just updated to latest firmware of App and camera firmware, seems like I lost ability to view SD card recording? I do not see the “Jump to SD Card” button anymore.
Before today, I had Android 2.46.0 (b365) with firmware 1.3.20.1991, with SD card playback working. Only few minutes ago, I saw firmware update, so I updated, and the SD playback feature is gone.
I do never had subscription.
What does this mean? Are we missing the end of the sentence? Just trying to understand what the bug is so we can test it.
When the motion detection zone…what? Or does it just always turn on the spotlight at midnight? What does midnight and the motion detection zone have to do with each other for this bug?
EDIT: Jason Fixed it:
I was reviewing BCP Beta FW. I have noticed that there appears to be no way to view the SD Card. The Arrow designates where it exists on the V3pro and OG Cam. On the V3, there is a View Playback option at the bottom of the live stream page.
@webcop33 reported the same thing above, just saw it.
Where is the Battery Metrics. On the WCOP, it is located under Settings Device Info. Or am I mistaken?
I cannot seem to find any Battery Metrics on mine.
It’s also missing. Looks like someone did a bad code merge.
@WyzeJasonJ … you may wish to halt this beta firmware test until these issues are resolved. We took a big leap backwards.
Just to clarify my situation. On beta firmware 1.3.20.1991, I had SD card playback. With latest 1.3.20.1993 it is gone.
Thanks, that makes sense. Probably used the wrong Branch to compile with. Speculating here though. :slight_smile:
Yep, sounds like a FW issue. Thanks for the clarification.
Siren button iis missing as well
Before Beta After Beta
SD access for BCP is also missing from previous beta 2.46.0.363. It’s definitely a firmware issue.
I still have siren access under all Android beta flavors.
Will someone else running iOS please doublecheck siren access?
ditto on android siren…sadly can’t test IOS though
I just looked at my iOS device and it does have the Siren available.
Devie Info shows:
FW: 1.3.20.1993
Plug-In version: 2.46.8
Here is a picture of what I see:
I am on iOS. Just noticed there is a 2.46.0 update in Test Flight… Hold Please.
Well Dunno if it was the update but Siren just came back
Fixed.
where is the “battery metrics report”?
It’s being held hostage by the firmware. :rofl:
