Wyze Battery Cam Pro firmware - Released 5/23/2024
We are releasing firmware 1.4.1.2289 today for the Wyze Battery Cam Pro to fix an issue that caused no event videos for Cam Plus Unlimited users.
Read our Release Notes:
is there way to flash BCP manually from SD card?
There is no firmware available for download on the release notes/firmware page so probably a big no.
Hi, I just got BCP and updated it to version 1.4.1.2289.
I’m experiencing a problem with error code -15 when loading the live view. This occurs repeatedly and can only be resolved by restarting the device, but the same problem reoccurs shortly thereafter. When this happens, no event videos are uploaded to the cloud, and no event notifications are triggered. However, I have checked and the video did record on the microSD card."
I have uploaded Log ID: 1427185
I am having the same problem – error code -15 when loading the live view, and no notifications. Menus come up easily, and like you, I was able to send in a log without error. Logs 1429486 & 1429488 (I have 2 out of 2 cams failing).
I have checked with my fellow Mavens, and no one else has the problem. So it may be up to a few of us to come up with enough clues for anyone to solve this. Your description and log was a great start, thanks! :slightly_smiling_face:
I am using an iOS app, are you? 2.50.7 (10). Maybe the problem lies there, although I wonder with no notifications.
I am also using the Wyze Router Pro, which indicates it is seeing communication from the camera. Both the camera and the router say there is good signal strength.
A battery power reset is a questionable solve, as whatever makes them work doesn’t always require that, and any solution is short-lived.
I’m have similar issues with my battery pro camera.
I had hoped the last couple of update there would be a fix that we get on our Android devices that when we have a 2K setting on the battery cams when playing back in events we gat an error code 9. I have submitted details of the issue and they seemed to agree there was a problem but no fix so far. Maybe it is coming.
[Mod Note]: Post moved from Wyze Cam v4 Beta Test 7/3/2024 to correct topic.
I have this issue on 1.4.1.2289 and 1.4.1.2290 beta. BCP connects fine to livestream after a factory reset or if I pop the battery in/out. But then 5 minutes later, I can no longer load the livestream anymore. Error code -5.
My cam v3 and doorbell are connected to same network and no issues there. It’s ridiculous this thing doesn’t work brand new out of the box. Seems like it’s been a common issue for several months now. This might be my last Wyze product purchase.
Welcome to the Forum, @jzondo! :wave:
Since you mention using the β firmware (in addition to production firmware) for your Battery Cam Pro, I wonder if posting about your issue to the newer β topic would help it to get more visibility before that firmware version is pushed to production.
Where do I find previous manual firmware updates?
Which camera? The are no previous versions available for download for the Battery Cam Pro. If the version numbers were Green you could download. No versions on the list are Green.
I’m not sure how I will ever be able to communicate with the battery cam pro since it won’t pair via the setup. Is it possible a future update to the Wyze app might fix it someday?[quote=“Antonius, post:12, topic:299878, full:true”]
[/quote]
I do not have a Battery Cam Pro. Maybe you can find your answer here either with the setup information or trouble shooting information. Go step by step.
https://support.wyze.com/hc/en-us/sections/13263005306779-Wyze-Battery-Cam-Pro
