Versions:
- Android: 3.3.0.b607
- iOS: 3.3.0(3)
What’s new:
- Added support for landscaping view in the Monitoring tab
- Bug fixes
Versions:
What’s new:
I hope it fixed the bug that has been preventing me from toggling motion notifications on V4’s…I’ve been getting non-stop motion notifications on some of my V4’s and the toggle won’t uncheck. ![]()
It’s not available on Android yet, but if someone gets it before me, see if you can toggle motion notifications on V4s, please. ![]()
I’m on 3.2.8 (604) and I can not enable notifications on a V4 (I normally have them off).
And not available to me - yet.
In my @#$%^&* iPhone, with now 3.3.0 (3), I still can not enable notifications on the V4.
I’m still on 3.2.8 but I cannot turn notifications on on V3 pros as well as v4s but I can with a normal V3, what the heck?
How are you trying to enable notifications? I am asking as I seem to be able to enable notifications except for all motion.
No discernible difference between 3.3.0(3) and 3.2.8(9) on iOS. Not sure what changed except the version number. ![]()
I see that a little in a different way and might have mentioned it previously.
When filtering events, if I check the pets checkbox it will uncheck.
But after a couple tries usually stays. Minor bug versus notifications turning off.
Android - b604
Are you by any chance participating in the Wyze Intelligence - Descriptive Alerts Beta? I was having the same issue when they forced the Unlimited Pro on me. Went away once they reverted the account.
Nope.
I am not in the Pro program, and they never stay on notifications no matter how many times I try either, again, both v3pro and v4
You are both right, I just checked and I have the same issue as well on both v3 and v4 versions 3.3.0(3) and 3.2.8(9) on iOS.
I just can’t understand how there is not a checklist of functionality to test before releasing to the “public”, even if it is to the beta testers.
Thanks. Will test it on my side as well.
I think they just got used to beta testers pointing them to their messes ![]()
To all,
Galaxy s24 Ultra
Android 14, December update
Appeared on Play about 4pm PST
It installed OK.
Tested V4 Notification toggle. It appears to toggle and stick. Have not tested functionality.
Not sure what I was testing in Monitor mode. If I turn phone to landscape mode it does not rotate. There is a rotate icon on the portrait screen. It works. While checking the v4 it auto rotates to landscape and has a rotate icon on the portrait screen.
Landscape mode looks good.
Cam Lite Person filter is still an issue on this Wyze Android beta app 3.3.0.b607. When I press on it, it prompts me to subscribe as shown here. It is an Wyze Android app bug only as there are no issues with Wyze iOS beta app 3.3.0(3). Last known Wyze Android app to be working was on 3.0.0.519 from July 2024.
Cam V3 manual recording a clip bug is back again with this Android beta app 3.3.0.b607. Android beta app 3.2.8.b603 had the same issue as well, whereas Wyze Android beta app 3.3.0.b596 sort of fixes it. I’m guessing this latest beta app merged with 3.2.8.b596.
Apparently it was on the cloud side because now v3p and V4 you can turn the notifications on. I have not updated yet.
You’re right! THANK HEAVENS!!! That has been driving me insane for weeks having my V4’s spam me about all motion and not being able to change it or turn off notifications for them.
I was at the end of my sanitfy. It seems someone must have seen our reports about it in here and got it fixed in the backend. I’ve been trying to be patient for the last 2-3 weeks hoping the next beta app would resolve it, and it turned out it was a backend fix. Good to know.
