Today we are releasing Wyze app 3.23 with a few minor bug fixes.
Versions:
- Android: 3.23.0.989
- iOS: 3.23.0.16
What’s new:
- Fixed an issue on Android where double click sounds would trigger incorrectly on the event list (Android Only)
- Other Bug fixes
Both the Android and IOS App versions are working well for me. I only use basic features (Live View, SD card playback and viewing Cloud Event videos).
Glad to hear we did not break any of the basic features with the update.
Thanks for getting the SAVE button back onto the MANUAL fan speed page on the Wyze Air Purifier!
If they can get us a firmware update that fixes the need to unplug/replug it every week or so, and fix the Indoor AQI Historical graphing this would be a great device…
Thanks again WyzeJasonJ for your help!
Let me see if I can track down where they are at on those issues.
The AQI you see on the device itself does not match what is on the Wyze Android screen most of the time, which may just be a timing issue. This could be a great device to monitor Air qualtiy in a room historically. You combo it with the Wyze Climate Sensor and you get Humidity and Temperature too.
It broke the wyze thermostat on android 18.
It shows offline.
It still works via Alexa.
How do I include a screenshot?
Same here, 3.23 on android 17 says that my thermostat is offline. Can’t live stream my camera groups as well.
Still have 3.22 on android 12 and it’s working flawlessly
Letting the team know. Can you please send in a log and let me know the log number.
Log sent in… 2598744. Thanks
this version totally broke preview. all cameras in multiple locations preview stopped working but clicking on an individual cameras works fine. android 17. was working fine before update today. both on wifi and att same issue.
v3.23 989
Can you send in a log and give me the log number
a camera device or a category what would u like. I have probably 40 cameras across 4 locations
Just pick any camera that is not lolading
App 3.23.0 breaks thermostat!
Went offline immediately. Android 18
Updated today.
Still works through Alexa
The same here as well as cameras in group view are not streaming… kinda annoying to say the least. I’m on the latest v3.23.0 (989).
2598786
it will eventually work for a while after picking individual camera then later same issue they will not. load in preview
2598875 log sent
The latest update for android makes my app say the thermostat is off line and unable. However alaxa and Google connect to it just fine.
