We have a Hotfix to release today. This should fix the thermostat bug!
Versions:
- Android: 3.23.1.994
- iOS: 3.23.1.3
What’s new:
- Fixed an issue that was preventing users from using the Thermostat (Android Only)
- Other bug fixes
Versions:
What’s new:
Confirmed. I can access the thermostat again on my Pixel 10 Pro XL
Thanks for the fix, All back to normal so far.
Thermostat is up and running again, but I’m not happy. First their camera smart recordings went dead, now this. I’ve just ordered a new smart thermostat, and opted not to renew Camplus. These kinds of customer sunset supports are pushing me away day by day.
Same, can now see 2 of my 3 - why 2 you ask…? 'cause I tried to reset one of them during this mess, as I was heading out to a different state for awhile and really needed to control them from a distance. It, of course, resetted but then couldn’t join the app so couldn’t get to working, So it’s just dead till I’m home in November. Fortunately there’s a upstairs/downstairs, and I didn’t mess with the downstairs - it should keep the house ok, but really, incredibly inconvenient, borderline malfeasance… Timing’s everything, and this created a mess..
I have been unable to locate the hotfix… I even uninstalled and re-installed the app… No luck through the Play Store for Android… Is there an APK or something I am missing??
Play Store → profile pic (upper right) → Manage apps & device → Check for Updates
After hitting Check for Updates a couple times, it showed up.
