Wyze app 3.2 Release Candidate Beta Test 10/10/2024
Versions:
  • Android: 3.2.0.b576
  • iOS: 3.2.0(5)
What’s new:
  • Added the ability to toggle the Autoplay Video Live Stream for cameras on the Home tab via the App Settings on the Account tab.
  • Added support for two Camera Card Styles, Comfortable and Condensed, available in the App Settings on the Account tab.
  • Bug fixes
The above were already available in the previous version iOS: 3.2.0(3) :thinking:
@habib
@WyzeAndy
I agree. Features were added in Android 3.2.0 b574.
Last item listed is bug fixes–yea
3.2.0 b576 appeared on Google play.
Update went well.
OG and OG-T bug resolved.
So far so good. Watching to see how notifications stack or unstack.
3.2.0.b576 installed here too. Will start testing on some Android 12 and 14 devices.
Installing b576 now. Will start testing soon
Thanks. Renamed OG successfully.
I don’t have the stack problem on an S23 Ultra,
Mine stack after 4 come in I think. Have you tried submitting a log to Samsung support?
I was just curious as I read the thread about stacking and unstacking. I can’t find the thread right now but if memory serves me the poster was complaining about having a large number of notifications, each having to to be singularly dismissed. I don’t have enough notifications to have noticed a problem but just checked. I had one notification that referenced 2 wyze notification. I was able expand the single notification and see the 2 individual notifications. Was able to unexpand the notification and dismiss in one swipe.
Seems very usable to me. Someone with 10’s or more notifications should chime in with their experience.
That’s me, 20 or more sometimes and they always stack. And sorry, I thought you had the problem.
No problem. I was looking through that thread hoping I could figure out why my camera notification settings were wonky. Wyze did a fix last night on the cloud that magically fixed that issue.
Just to get the following into this thread.
There seems to be an issue with OG and OG-T cameras showing events in the SD playback time line. It has persisted in this b576 release.
I’ve noticed this on my Samsung S23 Ultra actually in several versions of the app.
I have an Orbi RBK53 mesh, 1 router, 2 SATs.
It broadcast 2.4ghz and 5ghz simultaneously.
I have a primary and a guest setup.
All Wyze cams are on the guest.
If my phone is on the primary WiFi connection, OGs will get stuck with the bouncing balls. V4s do not get stuck. I forgot to check Pan V3s.:person_facepalming:
If I switch phone to guest, All cameras open rapidly as usual.
Any idea whats going on with that? I’ll continue observing and testing.
I’m guessing that when your phone is on a primary WiFi the feed from the cameras gets looped through the internet to reach your phone. When the phone is on guest the loop is direct. Sounds like Wyze server issue to whatever servers OG connect to.
3.2.0 b576
Android 14
Samsung S21 Ultra
@G2740,
Interesting problem. Of my 10 cams one is OG, one is OG-T.
I do not have a guest network therefore I have not seen what you are seeing but I have noticed the OG’s acting a bit different than my other wyze cams.
They load fast.
As 3.x progressed the bouncing balls/live view problems became more prevalent. For a while when I opened a group all my cams, except the OG’s, would have bouncing balls and failed live view. The OG’s always seemed to open right up while the other cams were in distress. So many things were going on with 3x that this observation took a back seat. This issue has been greatly reduced in b574 andb576.
Another observation is I think the resulting image quality on the OG’s was not as good as my other cams. I guessed that the OG’s were doing a different level of compression that allowed them to load faster but reduced the quality of the image. Note:this is speculation on my part.
The fact that only the OG has this problem leads me to thinking there is a compatibility issue with the OG and the router.
Just out of curiosity have you tried setting the resolution on the OG TO 360p?
Let’s see if this issue gets the attention of others with the same setup as you have.
No, but I’ll try a lower resolution in my testing.:+1:
I forgot to mention, if I go back to primary connection on my phone, its also works ok.
Just seems to get stuck once in a while.:thinking:
For now, I’ll leave it on the guest connection a while to see if it duplicates.
Love this new option. Makes the home page much cleaner with the compressed view.
However, I have noticed you can’t toggle the Live Play. Anyone else seeing that? On Android and iOS .
Yep, currently, you can’t live stream condensed views so the toggle doesn’t do anything when Condensed is selected.
3.3.0 b576
Android 14
Samsung S21 Ultra
I have Auto play turned off and Condensed selected.
I have all my cams singularly in Favorites and also in a group named Cams.
This what my Favorites looks like.
If I click on any singular camera it opens to that camera and goes “Live”
If I click on the group named Cams all 10 cameras start Live Streaming, “BTW–this has been vastly improved in b574 and b576”.
