3.17 Beta:
Versions:
- Android:3.17.0.b894
- iOS: 3.17.0(5)
What’s new:
- Introduced guest shopping to allow users to browse products, build a cart, and complete checkouts without requiring an upfront login or signup
- Bug fixes
3.17 Beta:
Versions:
What’s new:
Installed Android app with no issue. However, this beta release seems to be ignoring the do not disturb option on Android. Previous version would not notify when set, this beta release is.
Log: 2431795
On Android. Both my tablet and my phone now notify while in Do Not Disturb mode. Previously the notifications were silenced while in DND as expected.
Also experiencing the DND issue on Android (Samsung S24U, Android 16, OneUI 8.5). I’ve had to silence notifications completely.
I would be glad to:
Log Number is: 2445012
No message being presented. Here is the issue:
Prior to this Beta Release, you can put your phone in Do Not Disturb (DND) and all audible notifications are silenced unless the app or individual is on the allowed list.
It should be noted that I do not have my Wyze App on the Allowed list.
Since updating to the latest Beta, the DND is ignored and notifications remain audible and frequent. I received notifications for Motion Sensors and cameras. My V4 Cameras, outside, notify my continuously. I have to set my phone to vibrate only.
There must be a bug which is bypassing the DND setting on the Device. One possibility is setting notifications, in code, as an Emergency. It is my understanding that emergency notifications bypass DND settings as it is an emergency.
While in do not disturb mode, I am receiving camera notifications. I do not receive door sensor notifications, only camera.
I have done some more digging and have found the following:
I have submitted two different logs. The first log file is with just the first WyzeMessage notification option on, the second is with both notification options on.
Log numbers 2445033 and 2445040.
Same as the others have reported. They are just normal detection notices of my dogs walking around the house at night. Previously do-not-disturb mode would silence motion notification when on. I’ve been turning off the notifications at night manually in the Wyze app since this started as I don’t want to be woken up every time a dog decides to stretch his legs.
My indoor cameras are all v4.
Appears to be fixed. I have not manually turned off notifications at night since the update and have not had any notifications violate DND. Thanks.
Seems to be corrected on the latest Beta Release: 3.18.0 (b906)
@WyzeEnTing , can you confirm the fix is in this build?
