Versions:
Android: 3.10.0.b743
iOS: 3.10.0(3)
What’s new:
Added support for Widget in glass mode & dark mode (iOS ONLY)
Bug fixes
Versions:
iOS: 3.10.0(3)
What’s new:
Bug fixes
Installed on both iOS and Android. Curios as to what changed for Dark Mode in iOS. It seems the same to me.
I am seeing the same SD Card warning on all cameras, after the 3.10 Beta update.
Samsung S23+
Pan Cam V3, Doorbell Pro, Floodlight V2, Battery Cam are all showing the warning.
I did also on S24 Ultra and S10 Ultra Tablet.
I’ve seen it before,
so I just clicked don’t show this anymore.
Just saw it on my Battery Cam Pro. I formatted the Card and it went away
I’m unreasonably excited about my shortcut widget FINALLY being in dark mode. Was just thinking about this a couple of days ago. Thanks and please keep darkening more app displays!
I see the same on all models of cams under this beta app version. The message is not present viewing the same cams from previous app versions. Reformatting the cards in all of my cams would be brutal, especially when there is nothing wrong with my cards. I’m just selecting the “Don’t show this message next time I insert a microSD card” checkbox and tapping the Dismiss button. This must be a bug, as the message is blindly displayed for all cams regardless of firmware version and card integrity.
The other issue is that the message is not account-persistent. It is viewing-device persistent. I.e., you can select the “Don’t show this message next time…” checkbox and Dismiss on one phone/tablet. Start a live stream for the same cam on another phone/tablet and the message is displayed there also.
Normally, the app comes out days or a week or so after it has been announced here.
So, why am I seeing 3.10.0.745 beta being offered to me, and there isnt anything mentioned here, FB, or e-mail?
3.10.0.745 is a production release. Announcement here: Wyze app 3.10 - Released 1/22/2026
It has been announced in Discord and the Forums. Here is the link:
Play store showed it to be Beta
I must be blind cause I don’t see a link to download the update?
Beta app version 3.10.0.b743 for Android is no longer available. This topic and referenced beta app version is over 1 month old.
The latest app versions as of today, Jan 25, 2026, are now:
The announcement topic for the latest app versions is located here:
Okay? I guess I’m an idiot cause I still don’t see an update link or is the beta just for certain people to test?
There are no links to download beta and production apps. Apps are updated externally via Google Play Store (Android) and Apple App Store (iOS/iPadOS).
Beta apps and firmware are made available only to those who join Beta. Instructions here: Become a Beta Tester for Wyze Products & Releases
Please keep in mind that the purpose of beta is to assist Wyze in identifying and reporting bugs and usability issues before software and firmware enhancements are released to the general public. That means you will most likely encounter issues running beta apps and firmware… some minor and some major. If you value stability or rely on your Wyze products for security, you may wish to reconsider participating in beta releases.
What brand/model of viewing device are you planning on updating? And which operating system version are you running? Some models of phones/tablets will not work with latest app versions.
Thanks for the info, I appreciate it. I’ll keep an eye out when you release it.
