Wyze 2019 bulb
Over the past couple years I’ve changed out my WiFi router and each time had difficulty adding the bulbs back into the app. Right now it goes through the whole set up process but once I get in the app to try and control the brightness or white color, it causes the bulb to just turn off and then it starts flashing almost as if it’s trying to pair again. I’ve tried this with each of the 5 bulbs I have and it’s the same issue
Does anyone have a solution?
I have my wifi set to WPA2, 2.4ghz - not sure what other settings would be causing problems or maybe it’s wyze not supporting this bulb anymore ?
Not that problem, but one of my older Wyze bulbs just turns itself on and off as it pleases. I have tried a dozen times to remove it from my system and add it back in. But it still does what it wants.
Buy Meross or some other manufacturers Smart Bulbs.
