Possible to add another Wyze Mesh router wireless within the range of the (wired)25ft cat6 cable, root router… And use it as pass-through connection kinda Access point
Was planning to add another node in the garage to connect a wyze black pan cam V3 outside mounted in the tree
Thanks for the help
With regards
Willem
Welcome to the Wyze User Community Forum @wacbudde1970!
I have 3 Wyze Mesh Router Pros. The root is attached via Ethernet to my modem, the other two are Sattelites attached via Wireless Wifi.
It is actually quite easy to add Sattelites to the root Mesh Router. After they are added, they will assume the same SSID and Password as the Root Mesh Router.
