Had to get a new router today and now I cannot connect cameras back to my wifi
- You could set the router SSID and password to the same thing it used to be with the old router. That resolves it easily for most people if they are just hoping the cameras will automatically reconnect (you may have to power cycle the cameras so they try to reconnect again)
- If you are trying to go through setup again to assign them to the new SSID/Password, you can try temporarily disabling the 5GHz band on the router, then go through setup, then it should connect easier, then you can turn the 5GHz band back on.
