I just can’t figure out how to reconnect my cameras to the new network! Please someone help
Welcome @kipC
Best thing to do is keep the same SSID and Password as your previous router. Then the devices should just connect.
If you cannot do that, you would need to press the setup button and go through the setup. However, do not remove the cameras from the app as that will keep all settings.
