So I changed internet provider and had to purchase a new router. How do I get connected to my cams to the new router
Unless you set the new router up with the same SSID and password, you will need to hit setup on all the cams and set them up again. You do not need to delete them from the app, but do need to go through the setup again.
That may not be 100% accurate . I had to replace my existing router and I DID set the same SSID and password. None of my cams, plugs or sensors came back. I had to re-install the whole lot.
If you give each camera the same name that they had previously they will retain the settings they had before.
I did forget to mention that important part
Ok thank you, I figured that I would have to do it
