New router, how do we redirect camera"s to new wifi password without reinstall.
There isn’t anyway to change the wifi settings within the app. If I remember correctly you can press the reset button on the camera and then add it back and not lose any settings, but the process is very similar to an initial configuration. There are plenty of posts about this on the forum but you need to search for them.
You could use the same SSID (Name) and password as your old router and it/they will connect automatically. If you do use same SSID and password you need to set up again… What camera? If using the WCO and base you will have to plug the base into the router ethernet to set it up.
