How can I change my WiFi settings in my app on my I-phone? Need to change my WiFi Router.
If you are talking about the SSID and password you can’t, you have to reset the camera and go through setup again. The only way to have them connect to the new router without dong that is to set the SSID and password of the new router to the same as the old one.
Which is really easy to do! So many people seem to think they have to use whatever default SSID their ISP provides or their router automatically generates. You don’t. You can exactly match the SSID and password you had all along, and not have to change another thing when you replace a router…
