New wifi router
I just changed cable providers whats the easiest way to connect the cameras to the new router ?
Also wanted to thank everyone for helping with my previous issues. All the cameras are working fine now.
You simply need to go thru the setup procedure again with the new network name and password:
https://support.wyzecam.com/hc/en-us/articles/360022501071&?section=how-to-setup-camera
The easiest way is to configure the new router with the exact same wireless network parameters as the old router. (i.e., the same SSID and password). If you do that, the Wyzecams will be unaware that the router was changed and will continue to operate as before.
If you can’t (or don’t want to) retain the same SSID, you’ll need to setup each camera all over again.
Tjsnks guys
