Why Required login every-other day for Cam3s/ android
Why Required logins for Cam3s on Androids
The app relies on a persistent, cached data token to remember the login session; if that token is continuously destroyed or invalidated, the app forces a re-login.
If you are having to log in often, then it is usually a problem with your local device causing this somehow. This problem isn’t happening to most people. Often this is caused by one of the following things:
  • Third-Party “Clean-Up” Apps
  • Aggressive Browser Privacy Settings
  • VPNs
  • Android Battery & Data Optimization (or similar tools)
  • “Trust This Device” Glitches
You can often resolve the issue by updating some OS settings, bypassing your VPN, telling cleanup apps or privacy features to leave Wyze alone, etc.
Thanks for your reply. That is what is probably happening.
I will try some of your suggestions, if I can figure out how,
I have 6 cameras feeding 6 Amazon Fire Tablets. It happens on all 6 Fire Tabs. It is really driving me crazy. I have had this exact setup for many years and now all of a sudden I have this login problem. Have any other suggestions. Im might can the Fire tabs or even the cameras because I don’t want to have to login everyday. Thanks, again
Just to echo what @carverofchoice said, I’ve never been logged out on my android phone, unless I forcibly clear the app data and reset it, or uninstall and reinstall the app.
I have an old phone running the old 2.5 app too, I hardly ever use it anymore, that one will log me out, probably after a couple weeks of no use.
Something on your phone is clearing the data or blocking cookies/tokens it sounds like.
Probably not fully compatible with Wyze App that is built for standard Android devices.
Thanks for the reply. I agree that it is not fully compatible with the Wyze App. Amazon wants people to use Amazon cameras and subscriptions.
Thanks for your reply. I’m working on the possibility of our idea.
I have another suspicion. I just signed up for Amazon Prime, and Amazon changed the Alexa service to the one for Prime. perhaps they also changed the the OS on my Fire Tabs. Not sure but suspicious.
