Hello,
I have a Wyze thermostat. The following pictures are the settings. Can anyone tell me why there thermostat and furnace are not changing the temperature down to what I have it set at? It says it’s 71 in the room and I want to turn it down to 67.
It’s because 70 is in the range shown for home. If it’s 70, and you have the range set to 66 - 76 in heat mode your system won’t do anything because the temperature is already in that range.
Also, since you’re in heat mode and not auto mode, it will only turn on the heat if it’s below 66.
If you turn on auto mode, it will heat if it’s below 66, and cool if is above 76.
