I set my Wyze Thermostat to 66 degrees this morning. The thermostat read “Heating to 66,” and the furnace came on and warmed the house. A couple of hours later, I noticed the house was getting colder. I looked at the thermostat and it said “Heat to 55.” Naturally, if I left it this way, the furnace wouldn’t come on until temps reached about 54.
This has happened a couple of times with my new furnace. Anybody know why? I don’t have schedules set.
It could be the default “Temperature preferences” are overriding your set point. Access them in settings for the thermostat and Change them to what you prefer.
Is there a way to remove all schedules? I’m in and out of my house at different times each day. A schedule (whether default or not) doesn’t work for me. Thanks.
