Where is the submot button in the Wyze app?
Wyze V3 Android App. When viewing events it asks, Improve our AI by sharing this video. A button that says YES. When you click yes it pops up a new screen and says what was in this video. Then it says by hitting submit you agree to… There is no submit button. I see nothing in settings. Where did it go? Is it turned off?
I think the app is current. Not sure where to look. Cameras are updated.
@BMann,
I can confirm what your seeing. Not sure when it crept in but I see the following on wyze beta b604. It is related to android >settings > display > screen zoom. In my case I have zoom one notch higher. As a result you can see the submit button chopped in half.
If I set zoom back to default this is what I see.
What is your zoom set to?
This more proof that Wyze never seriously tests anything it rolls out.
Why would they when they have users to do all the testing :rofl:
The Beta testers are really Alpha testers :rofl:
The end users are the Real Beta testers :joy:
Wyze has Millions of Happy Beta Testers :rofl::joy::rofl::joy:
@habib , @bryonhu ,
I didn’t sign up for beta tester. I guess we were drafted.:slightly_smiling_face:
I did sign up, what that makes me?
I will hold my tongue🫢
No holds barred my friend, I can take it as long as it conforms to forum guidelines :wink:
That was it… Kind of strange my display is on medium and it cuts it off right below the paragraph. If I hold the screen and try to scoot it, the buttons are not there.
I only have options of small, medium (default), and large.
Thanks, Not sure if I want the display size stuck on small all the time. ???
@BMann,
I would give it some time. Over the years, as eye sight has changed I’ve been increasing the zoom factor. I have seen multiple instances of this, from various vendors. Sometimes it gets fixed, sometimes it doesn’t. Wyze seems pretty good about fixing it.
I know, I know, why don’t you just increase the font size? It’s not the same.
That’s okay. I have my Tourette’s under control today. :grinning:
It is what I have been used to with the phone and not sure if it will goof up any of the other apps.
I will give it a try for a while and see if I like it.
If it was cut off partially or I could scroll to it, I could understand. But since it was cut off cleanly and I could not scroll down to it, it left me wondering.
The “Submit” button is probably cut off. This has been a pattern with Wyze developers; they assume a certain screen aspect ratio. And when run in a device with a different ratio, their screens cut off a portion of the display because they always forget to include a hidden scrollbar. The hidden scrollbar should allow for touchscreen scrolling.
