Just checked and it does not seem to be available in the Google Play Store yet. Will keep checking
EDIT
Just got it, will test and provide feedback
First Issue, unless it was moved: The VoIP option for the VDB to call your phone is missing from the App Settings area For Android 12. on iOS, you see the VoIP Option but no option to turn it on. I use it a lot and found it very handy.
EDIT on Issue 1: On Android it was moved to the Accounts Menu, Notifications, then Push Notifications
Issue 2 When you view the VDB, the Settings icon and the Close icon is up too high. The close icon is actually covered by the Camera on the Pixel 5. If you tap a little below and to the left they will function. But it was hard to find the spot. Image below has arrows to where I am talking about. Notice how the Settings icon is over the battery percentage. Note: iOS 15.1, I do not see this issue.
Just a heads up for anyone wondering @Mavens about it, the VoIP settings have been moved and they are now in a different area. One that’s not very intuitive but after a second of thinking makes sense.
Go to the settings page, >notifications, > push notifications for the VoIP settings. No doubt people will be asking about this and where they disappeared to.
You are Brilliant. I thought it got left out. Thanks for the update. I posted 2 pictures above and notice iOS still has a form of VoIP located in the Applications Settings.
Also, you are correct in that it makes sense when you think about it. I actually went to the Doorbell Settings area to see if they moved it there since it is only related to the doorbell. But it wasn’t.
I am not a fan, but, I am also very familiar with the app.
Space is already limited especially if you have an abundance of Wyze devices … with that.
Good opportunity to provide “How To” information, but yes, we should be able to control visibility.
I can only assume that there was some intent given it’s on one platform and not the other.
