Web View Not Accessible Since 12/1/2023
Been using web view for a year or so with good results until 12/1/2022. I have not been able to access my cameras when logging in to web view. Instead of seeing my cameras, now I get:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<error_description>Full authentication is required to access this resource</error_description>
unauthorized
I have tried up to date Chrome and Edge browsers as well as incognito window with the same results. Cache was cleared… same results.
Has anyone else had this issue?
I just opened Web View. Three or the four cameras will stream. The driveway cam is a V3 Pro and it will not stream/load live view, the other cams are V3 and they will load. I’m using Chrome 108.0.5359.95 (64bit) just updated a day or 2 ago. I can view events for all 4 cameras.
There were some outages the last couple days, and that error you are getting is usually right after you login. Try logging in at wyze.com, then go to view.wyze.com
That worked! Thank you for your help. My three cameras are up and running.
