This is the message in my Chrome browser:
RequestHeaderSectionTooLarge
Your request header section exceeds the maximum allowed size.
8192
W8GYPD3ZMNV0704R
v5rwM5T6vYDVt2XGmzwYmLN/jBMMfgOwlChbMz+O3PeE9hSUie4OM0i2pWa/btoOTwDwXBUS2SM=
8192
W8GYPD3ZMNV0704R
Howdy,
This is a more common issue than you’d think. It doesn’t just apply to Wyze’s site, you need to clear your browser cookies and try logging back in. If it still fails, clear your entire cache and cookies, then try again.
Chrome somehow tries stuffing a ton of data into it’s request and overwhelms certain HTTP server software (like Apache2). I’ve had that happen with clients’ servers running Apache with Invision forum software.
I also tried Firefox and received the same message.
Hello again,
Have you tried the same solution I mentioned? It also applies to Firefox, or any other browser. It usually seems to be a cookie/cache issue.
For other folks having the same issue, try this:
That’s the most common solution that seems to work with most people who come to me with this issue.
Otherwise, you might need to contact Wyze support and inform them of the error you are receiving, it could be a server issue.
Hi Mike,
I did as you said in Chrome. I cleared the cache and cookies. It worked! Thank you for your help.
