WCO siding mount hook
I was looking at a siding mount hook to put the outdoor cam on but then I read one review that said it didn’t fit the WCO. Has anyone found one that works for them?
https://www.amazon.com/Siding-No-Hole-Needed-Outdoor-Security/dp/B07XG17SPY
I bought these in white on @stevebergmann’s recommendation. They have a small articulating arm so you can adjust them to any angle. They were super easy to mount/adjust and are working great. Just pull the magnetic base off of your cam, screw the mount into the cam’s threaded hole, tighten the locknut, slide the mount and cam under your siding, adjust the mount’s standoff with the two thumbscrews, adjust your viewing/detection angle and tighten the big wingnut on the mount to secure your adjustment. :+1:
