VPN support on routers and more router control
Hey is there any way to get support for VPN onto the routers. Where we can set support thru the app or even thru the web gui. Since the parental feature as be removed it can take it place
Support of ad guard VPN or others would be awesome if I can just get this would the router even better
And
The ability to remove devices that have been offline for while or that are gone would be great
Thanks
