Dear All:
In November 2022 I placed a note about jumpy videos in this community:
In the meantime I tried with the support team to find a solution. They asked me to check the following:
1. Please ensure that your Wyze App is running with the latest version. How to update your Wyze app.
- Same goes with the camera’s firmware, ensure it is up to date. In the App>Account>Firmware updates.*
- Please force close the app, then re-open it.*
- Kindly check the signal strength of your camera, In the App>Camera>Settings>Device Info>Signal Strength, ensure they are getting 3 full signal bars, this means the camera is getting stable connection from your network.*
- Once confirmed, please un-assign and re-assign the service to the camera.*
To un-assign and Re-assign:
- In the App> Go to Account Tab.*
- Select Services> tap on Cam Plus*
- Tap the drop-down arrow next to the name of the camera.*
- Then select Unassigned License*
- Vice versa to re-assign.*
- Once assigned, kindly power cycle the camera by unplugging it from the power outlet for 30 seconds, then plug it back in.*
- Test your cameras by making a motion in front of it, then review the recordings.*
My response:
My Wyze App is running the latest version.
Camera firmware is up to date
I closed the app and re-opened it
The signal strength shows 3 full bars
I un-assigned and re-assigned
I power-cycled the camera
I tested the camera - no change!
So no luck. They closed the ticket without letting me know.
Does somebody know a fix?
I appreciate your comments
Best wishes
Henning
