I’ve just installed the above mentioned firmware update and it now seems that when I review recorded events they are showing in half-speed. The default is 1x but the picture stutters. If I change to 2x the picture is smoother. Am I the only one experiencing this?
Have you tried power cycling the cam? Not just a restart, but pull the power cord, wait 30 seconds, then plug it back in. Does that fix it? I have multiple cams running on the latest version. I have viewed playback from a couple and all is well. With that said, I have not checked them all…
Edit:
I spot checked all of my v3 cams and playback is good to go on all of them. Hopefully a power cycle of your cam resolves the issue. If not, maybe try formatting the uSD card. If none of that does the trick, I would highly recommend contacting WYZE support. Best of luck!
All seems well now! Seemed to fix itself!
Awesome!
