On the robot vacuum mapping, I love the green color of the walls, the yellow color of the charging base, and the white lines of the swaths. I request that the moving dot of the vacuum be another color than white, because it always takes me a minute to find the vacuum amongst the sea of white swath lines. Thank you.
MOD NOTE: Title Edited To Enhance Search Clarity.
I’d like to request that the software for the robotic vacuum be altered so that the position of the vacuum when operating properly is shown in green. And when stuck or malfunctioning it should change to a red x. As good as the robotic vacuum is it does tend to get stuck once in awhile and it sometimes hard to see in a large layout exactly where it is.
Wyze robot map
Change the color of the robot when viewing map. White on white is hard to find when robot gets stuck.
[Mod Edit] Merged with an existing wishlist topic. Give it a vote to help it along!
