man my app still isnt showing this firmware. does it matter im on the beta testing version I wonder? Also thanks to @AverageDude because so far 2 of my most recent 3 Cam v3 deaths are back to life using that older firmware… and I dont get why Wyze wouldnt suggest a fix like this the only thing that comes to mind is that its the security features or something that is causing the problems and its less a hit for them to warranty than to defend against whatever could happen from a security breach? I dunno but hooray these will be put back into the squad on light duty areas ![]()
Since you joined the BETA program, you will only see BETA releases and not official public releases within your app. If you want to see general/public releases, you have to unjoin the BETA program.
Glad to hear you are bringing some of your v3 cams back to life! Now that you have them up and running, are you going to try to update them again? Nothing like an ever ending loop. What a PITA.
For the record, the issue persisted with this version of firmware as well. Another release, another manual update required…
4.36.9.139 (May 18, 2022)
- Added support for garage door controller trigger duration settings
Edit:
If someone that works for WYZE would like me to send them this camera for troubleshooting…I would be more than happy to take a refurbished unit as an exchange. Just throwing it out there @WyzeJasonJ
