So I use both V2s and V3s, some with Plus, some not. They ALL used to pick up and record 12 seconds of basically ANY movement. A leaf on my tree moves, it would pick it up. But the sensitivity is not the issue. Now my cameras ONLY pick up and record People. I want them to record smaller things like my cat jumping down, a bird coming to rest and eating a bug… stuff like that. Now they ONLY record people.
I have tried to change the myriad of settings in the app but to absolutely no avail. My only thought is that this must be some app “Upgrade” where it tags People but fails to care about anything else.
How do I make it record any small movement? Like they used to!!!
Check the “Event Recording” settings in the app. Also, make sure you don’t have any filters enabled in the events tab. Click the funnel icon in the upper right, and hit clear.
If you have a subscription you can set it to detect only what you want and turn off “other motion”. If you don’t, then using detection zone and sensitivity settings can help cut back on the false alerts.
