V3 just quit recording continously to SD card 2 days ago? - Just an observation, no help needed (2 out of 28 Cams did this)
I have CamPlus Unlimited and one of my V3’s just decided to quit recording to SD two days ago.
Just love Wyze’s bug ridden software/firmware, always something new in a bad way…
Well formatting and toggling on/off/on SD recording fixed it, although I should not had to do that if these Wyze cams weren’t such junk when it comes to stability and bugs in software/firmware,
I don’t recommend Wyze to anyone because I will have to fix it for them to often, only techy types I would say give it a try with a warning as to the constant issues with upgrades, etc…
Checking my 28 cameras currently, found a second one with same issue…
Wyze is Definitely NOT a Security Camera Company, just too unreliable for that task :face_with_symbols_over_mouth:
Glad I have other more reliable cams from other manufacturers for Security.
Trying different ways to restore “Continuous Recording to SD” On the second one it just took toggling between “Event Only / Continuous” and toggling on/off for SD recording then rebooting camera via app.
Did NOT format SD this time
EDIT: 2 out of 28 cams had this issue. No more testing results from others to post
I one of my older V2 cameras that does that. Just stops recording every few days. Stopping and restarting recording brings it back for a few days.
This is going to sound silly but I had a similar problem last week with a V2. Format failed, 0 capacity. After playing with it for more than an hour reformatting on my computer, trying again, reformatting, toggling switch, rebooting … even if this card was working on another camera… I heard a very slight buzzing sound. I changed the power supply and that solved my problem. This was the first time since 2019 that I have had to change a power supply on one of my cameras which are still on continuous recording with the same cards. It costs nothing to try.
My power is very clean and I’m not using a Wyze USB power adapter…
Since that post the number of cams has increased and Amp Hours on batteries too…
