V3 Cams at multiple locations
I currently have 6 V3 cams at my location, my daughter has 5 V3 cams at her home several miles away from here. She is out of the country temporarily and has shared her cams with me. I have just purchased two V4 cams that I wanted to put in her home to overcome some blind spots. I know her router ID and Password but can I use my Iphone to install these at her location? Will they show up as my cams or show up as “shared” cams? I also have CamPlus on my account. Do you see any problems with this? Thanks.
You can set them up on your account using your daughter’s wifi. They’ll be on your account and will work fine.
I take it that you have physical access to her house. As long as you set up the new cameras while you are on your phone on your ac count but on her WiFi, the new V4 cameras will work on her WiFi, but will be on your account. For the time being you can share those cameras with her. Once she returns, she can do the setup on her account for those cameras and that will move them to her account.
Ok, that was what I was hoping for --thank you for the quick response.
Need to remove the cam from one account first, in order to add the cam to another account.
No you don’t - unless that has changed.
