V3 camera's no live view
After the cloudflare problem a couple of days ago my v3 camera’s are not showing live view but do record the events. Phone is pixel 9 pro xl running wyze app 3.8.7 and a netgear nighthawk rs500 router. What’s happening?
Have you tried rebooting the modem? Most ISPs use Cloudflare for various services. It might help to refresh your connection to your ISP.
Yes, That was one of the first things I tried.
John
What about the phone and cameras, did you reboot them?
Try the “reset services” in the app for each cam?
I already did that.
John
I hate to send you down a rabbit hole, but try deleting them from your account and reset them as new cameras. I know, it is a pain in the behind, but I honestly have no better solution. I have six V3s and one V4, and I have no issues whatsoever.
I still think it has something to do with your ISP other than router since you mentioned that the issue started with Cloudflare outage the other day.
Your User Profile listed you use Android and IOS. Have you tried Live View on both?
Did not work. I have live view on my ipad but just all of a sudden my pixel 9 pro xl stopped showing live view and I hadn’t made any changes to either my phone or my camera’s.
Sorry, I don’t think you want my advice as I don’t do Android. Maybe someone else more qualified will chime in with solution.
Try uninstalling and reinstalling the app on the Pixel.
