Hi, UK user here and have been since Oct 21. Generally quite pleased with the two outdoor cameras I have. One with upgrade package one without. The former always seems to be a bit more"stable" than the other one .
My current SD card in the non- upgraded cam has basically ceased to function. Can’t get it to work, tried to reformat both in and out of the camera etc. I have decided that the issue is the card itself so I am looking to get a new one.
My actual question is this. My understanding is that the “best” card to buy would be classified as High Endurance ( from a reputable supplier). However am I correct in understanding that it can now cope with 64GB rather than the 32GB that was originally recommend at time of purchase?
Yes, go with a High Endurance card. As you obviously know, the “official” spec until recently was 32GB max. I (and many other people) have used larger cards. I have used 64GB HE cards from SanDisk for several years with great reliability. I did test a couple cameras with one of the 128GB cards I normally use in my drone - which also worked fine - this was before the firmware update that officially allowed larger than 32GB cards. I think I heard someone was using 256GB cards, but I can’t confirm that.
I’ve been running 64GB, 128GB, and 256GB cards with continuous recording for years on all cam types. I’ve also tested a 512GB card, but the larger the card, the more painfully slow scrubbing becomes. I just repurposed this 256GB card out of an old dash cam yesterday:
@Seapup, dash cam, eh? Me too. Hint for you: I save an old failed Micro SD (extra) in my car, easy to reach. My dash cam helps keep me honest and a better driver. Because I don’t want to record my own stupid mistake. And to that end, I make sure I don’t make available to someone like “Jonny Law”, and incriminate myself. So, I insure that option is by my choice. If required/forced give up my recording, I am going to hand off the “extra” vice the one in the cam, even if I have to palm the good for the bad. Get me?
