Using air purifier offline
My wife wants an air purifier for her office, but there is no wifi service there. Will she be able to use a Wyze air purifier without internet service? I assume it can be turned on and run by pushing buttons on it, but I don’t know if features such as notifications about the filter needing to be changed require internet service.
Welcome to the community @garyww
To answer your question, Yes you can use it without WiFi. But without WiFi, you will not get any FW updates. you can control it manually with the buttons on the device.
To take advabtage of all features, having it connected to WiFi and installed on your phone would be required
I actually used one of mine completely offline for a while (several days) before I actually “set it up” in the app. It worked fine just using the buttons on the device without it having WiFi.
