Has anyone used the Wyze chime controller with an external relay? Trying to use the controller to activate a relay, which would then run the chimes. Would seem you can’t do this with less than two transformers, as if you trip the chime by connecting it to the transformer, the Wyze controller, continually outputs voltage until it cooks the transformer and itself. Thoughts?
Crease
March 9, 2025, 11:04pm
Welcome to the Forum, @justfishin !
Apparently, yes. Have you seen these topics?
I got a Video Doorbell v2 but I was running a VD v1. My original system I installed in my house 22-1/2 years ago is the NuTone IM-4406 Base Station and all the remote stations. At the front door, I had the pushbutton/speaker outdoor station and have the optional AI-29 Chime Module. This system uses two (2) internal transformers.
[IM-4406 Master Station]
When I installed the v1, I put in a new, dedicated transformer and wired the v1 to it. I added the Wyze door chime add-on and then just aband…
Based on what Wyze support just told me, The chime controller is only capable of controlling 1 chime. I have a one-doorbell 2 chime setup. One chime downstairs and one chime upstairs. A great upgrade option would be a way to hook up both chimes so I don’t lose out on a chime. I will gladly purchase a second chime controller if that would allow it to work. If there is a way to wire it up so that the controller can control 2 chimes a wiring diagram explaining this would be fantastic. I’ve been wai…
system
Closed
June 7, 2025, 11:04pm
