Use gas heat instead of Heat Pump
Hello,
I have a heat pump but I want to configure WUZE Thermostat to use gas heat instead.
Currently it is using my heat pump to heat. If I toggle emergency heat like I did with my old thermostat, it does set to emergency heat. However, you can’t adjust the thermostat in the ap or directly on the thermostat.
Is there a way to make my gas furnace stage one and make the heat pump stage two?
