I have a heat pump with emergency gas heat. When the temp drops below 45, the gas heat is more efficient than the heat pump. So can I switch from normal to emergency using the app?
Welcome to the community @tony_dercole
Unfortunately, there is no manual method to accomplish this at this time. Here is a Wishlist item requesting the ability to manually switch to Emergency vs Normal mode:
