Usb extention
One small question. I was just installing my wyze cam v2 and ran a bit short on cable. I was missing about 15 cm. Is it OK to use a USB extention along with supplied power cord? If so, any particular specification required for the USB extention?
Thanks
A USB extension should work fine I don’t have any set up that way but I do have 16 foot cords on some cameras
As @HDRock mentioned it should be perfectly fine. I’m using 26’ usb power cords I purchased from Amazon.
2 Pack 26FT Power Extension Cable for WyzeCam.
https://www.amazon.com/dp/B07VFCKR48/ref=cm_sw_r_cp_tai_gcD5DbQTSPM5M
