Updates to the Wyze Sense Hub to make it more Robust
I’ve been using the Wyze system for many years now in several homes and had to replace the hub several times..hub dead, battery dead, and just going off-line all the time (no internet problems). For the near future, I would like to see the below since the hub is the back-bone of the entire Wyze universe. I don’t care if it even cost twice as much, but I need a hub I can rely on (Ring doesn’t have a hub and works all the time!)
  1. Be able to replace the hub without having to re-link certain devices.
  2. Have a replaceable battery.
  3. Be able to turn off the beep sound every time someone opens a door. If the system is located in a room, then it wakes people up.
  4. Be able to completely turn off the hub (if you could remove the battery, than that would do it.) Makes it easier to replace.
  5. In the Hub Settings, be able to see battery life.
  6. Have a place to plug in an external alarm speaker, can just be an output.
Please make sure you vote for your Wish as one is not added automatically
